Xibo CMS with Docker on Ubuntu 22.04
This is a guide to install Xibo with Docker on Ubuntu 22.04, working through the Xibo for Docker on Linux instructions
For the purpose of this walkthrough I am starting with a standard Ubuntu 22.04 Server x64 machine, with at least 2GB of RAM, and 2GB of swap, logged in as the “root” user.
Install Docker
apt install docker.io docker-compose-v2
That’s all the dependencies for Xibo installed.
Install the Xibo CMS
Lets now install the CMS:
mkdir /opt/xibo
cd /opt/xibo
wget -O xibo-docker.tar.gz https://xibosignage.com/api/downloads/cms
tar --strip-components=1 -zxvf xibo-docker.tar.gz
We now have the docker-compose files extracted in to /opt/xibo
Create config.env file
We need to create a config.env file per the install guide. Lets do that, ensuring we set a MYSQL_PASSWORD value. This must be alpha-numeric only. ie made up of A-Z a-z 0-9. No spaces, punctuation or other special characters. For example, something like BTvjCyqQEZ8kGPrb would work. Clearly, do not use that password!
A link to a random password generator is provided in the comments and is the best thing to use!
cp config.env.template config.env
nano config.env
Save your changes and quit.
Now bring the CMS up
docker compose up -d
Please note: It is normal for you to experience a delay whilst the CMS finishes setting up, please be patient.
The CMS will be downloaded and run, and you should be able to log in at the IP address of your server. I have a DNS name pointed to my server (xibo.alexharrington.co.uk) so I can simply enter that name:
First thing to do is to change our xibo_admin account password:
Once that’s changed, we’re ready to use the CMS over HTTP only. Work through the CMS Post Installation Guide for setup information.
You should consider setting up a firewall. As a bare minimum, the following will set you up the ufw firewall with the right ports open for HTTP, SSH and XMR:
ufw allow ssh
ufw allow 80/tcp
ufw allow 9505/tcp
ufw enable
Adding SSL Support
There are several ways you could add SSL support to this configuration.
The simplest is to install Apache on the host Ubuntu server, and have it proxy the SSL requests into our container.
First, we need to stop the running CMS since we’ll need port 80 for our Apache server.
cd /opt/xibo
docker compose down
Now move Xibo on to a different port number.
We’ll be following the instructions to install Xibo for Docker on Linux from the “Using different ports” heading.
cp cms_custom-ports.yml.template cms_custom-ports.yml
rm docker-compose.yml
nano cms_custom-ports.yml
Edit the “ports” section of the cms-xmr and cms-web services so they read as follows:
version: "2.1"
services:
    cms-db:
        image: mysql:5.7
        volumes:
            - "./shared/db:/var/lib/mysql:Z"
        restart: always
        environment:
            - MYSQL_DATABASE=cms
            - MYSQL_USER=cms
            - MYSQL_RANDOM_ROOT_PASSWORD=yes
        mem_limit: 1g
        env_file: config.env
    cms-xmr:
        image: ghcr.io/xibosignage/xibo-xmr:0.9
        ports:
            - "9505:9505"
        restart: always
        mem_limit: 256m
    cms-web:
        image: ghcr.io/xibosignage/xibo-cms:release-3.3.5
        volumes:
            - "./shared/cms/custom:/var/www/cms/custom:Z"
            - "./shared/backup:/var/www/backup:Z"
            - "./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z"
            - "./shared/cms/library:/var/www/cms/library:Z"
            - "./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z"
            - "./shared/cms/ca-certs:/var/www/cms/ca-certs:Z"
        restart: always
        links:
            - cms-db:mysql
            - cms-xmr:50001
        environment:
            - XMR_HOST=cms-xmr
            - CMS_USE_MEMCACHED=true
            - MEMCACHED_HOST=cms-memcached
        ports:
            - "127.0.0.1:8080:80"
        mem_limit: 1g
    cms-memcached:
        image: memcached:alpine
        command: memcached -m 15
        restart: always
        mem_limit: 100M
    cms-quickchart:
      image: ianw/quickchart
      restart: always
So specifically, we changed the line:
            ports:
                 - "65500:9505"
to
            ports:
                 - "9505:9505"
and
            ports:
                 - "65501:80"
to
            ports:
Save your changes. That will ensure that XMR runs on port 9505 as before, and the web service runs on port 8080 only on the loopback interface.
Bring the containers back up with those changes:
docker compose -f cms_custom-ports.yml up -d
Now protect that Container with an Apache server and a LetsEncrypt SSL certificate:
apt install apache2
a2enmod proxy
a2enmod proxy_http
a2enmod headers
Edit the default apache config file to create a reverse proxy to our container:
nano /etc/apache2/sites-available/000-default.conf
It should contain
<VirtualHost *:80>
        ServerAdmin webmaster@localhost
        DocumentRoot /var/www/html
        ErrorLog ${APACHE_LOG_DIR}/error.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
        ProxyPreserveHost On
        RequestHeader set X-Forwarded-Proto expr=%{REQUEST_SCHEME}
        ProxyPass / http://127.0.0.1:8080/
        ProxyPassReverse / http://127.0.0.1:8080/
</VirtualHost>
Save your changes, and then restart Apache
service apache2 restart
Our CMS should now be available back on port 80.
If you’re using ufw, lets put a rule in for https traffic now
ufw allow 443/tcp
Then install letsencrypt (from Certbot Instructions)
snap install core
snap refresh core
apt-get remove certbot
snap install --classic certbot
ln -s /snap/bin/certbot /usr/bin/certbot
And then generate a certificate (replacing xibo.alexharrington.co.uk with the DNS name for your server.
certbot --apache -d xibo.alexharrington.co.uk
Do not select the option to automatically redirect requests to https connections. Once the certificate has been issued, try accessing the CMS over https. If it works as expected, log in to the CMS and in the Settings → Network tab, tick the option to “Force HTTPS” connections.
Upgrading
Upgrading is simple. The steps below show the steps to take to upgrade taking a full backup before hand. Run these as the root user.
# Stop the running container
cd /opt/xibo
# With SSL
docker compose -f cms_custom-ports.yml stop
# Without SSL
docker compose stop
# Backup the existing container data
cd /opt
# Delete any old backup version
rm -r xibo-backup
cp -rp xibo xibo-backup
# Download the new docker-compose files
cd /opt/xibo
NOTE: If you are upgrading then remove the old xibo-docker.tar.gz file to avoid creating duplicate files:
cd /opt/xibo
rm xibo-docker.tar.gz
If you didn't enable SSL, then
    docker compose pull
If you did enable SSL, then you'll need to:
    cp cms_custom-ports.yml cms_custom-ports.yml.old
Make the same edits to this file as in the install guide above, to specify the correct ports to use, and then run
    docker compose -f cms_custom-ports.yml pull
It can take several minutes for the upgrade to complete and the webserver to start - particularly when going between major or minor CMS versions.
    docker compose [-f cms_custom-ports.yml] logs -f cms-web
will give you diagnostic information as to what is happening. It is normal to see an error like
    mysqldump: Error: 'Access denied; you need (at least one of) the PROCESS privilege(s) for this operation' when trying to dump tablespaces
or
    AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 172.19.0.4. Set the 'ServerName' directive globally to suppress this message
and these can safely be ignored.
After installation of Xibo CMS 1.8.0 using Docker...now what?
Xibo 1.8.1 server 2016 install
Error in 1.8 installation in Ubuntu
Installing 1.8.1 in a sub folder
1.8.1 Released
What step am I missing?
XIBO 1.8.1 with docker on Ubuntu
Xibo Docker Upgrade makes fresh and clean install :(
Installing Xibo on a windows server 2012 virtual machine (Over Hyper-V)
Xibo 1.8.1 config to force https with own cert
Https vs Docker on v1.8.5
Install Xibo-Docker Ubuntu HTTPS
(Ubuntu + Docker) After Successful Installation nothing show up on localhost?
XMR issues post-installation
MySQL init process failed. Docker on Ubuntu 16.04
ZeroMQ install problem (Ubuntu 16.04)
Do not what Docker
Dashboard fails to load
Xibo for Docker on Windows 10 64 bit
Video instruction for install Xibo 1.8.x
Windows Player "Unable to connect to remote server" - Ubuntu 16.10 server
Docker install wont start
Installed as HTTPS
Issues with upgrading 1.8.1 to 1.8.2 with docker
Docker install on Ubuntu can't find config file
Error: Connection failed
Error during upgrading from Xibo 1.8.0 rc-2 to Xibo 1.8.0 stable version
Complaints about this Docker thing
Xibo on https with amazon web service issue
Reboot with customer ports docker - docker-compose -f cms_custom-ports.yml up -d
Error when running Xibo on different port
Need some advice on my software development mixed with xibo
HTTPS on Docker Install with own SSL Cert
Need to manually add the "S" to HTTP when upgrading from R202 to R203
CMS Not resolving after following SSL guide
Migration from custom install to docker
Error while fetching API version
Error running docker-compose up -d on ubuntu server 24.04.LTS
PowerBi not Show in Player
Turn on HTTPS on Xibo installed on docker
Where are the user and password from the docker guide from?
API Issues "error":0,"message":"API configuration problem
Upgrade 4.1.2 -> 4.2 Docker error when starting
SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo for cms-db failed: Temporary failure in name resolution
How to backup Xibo database on Docker installation?
Linux Player not Pulling layouts
Best way to back up Xibo CMS installed on Docker
Upgrade manually from 1.7.9 to 1.8 not working
CMS 1.8.1 Content will not be downloaded by Windows Player
Couple of quicks when upgraded from 1.7.4 to 1.8.0 through 1.8.2
Displays Not Downloading Dependencies
Write error on the library (docker install)
Version is unsupported docker error when trying to start xibo
Cannot save, error finding a file
Question about multiple setups (new to Docker)
CMS shows same private IP for different displays
Two questions? install xibo in win7 32 bits or ubuntu debian
Upgrade and backup
CMS behind reverse proxy
Difficulty installing 1.8.1 with Docker
1.8 in Docker with Reverse SSL Proxy
Docker container does not start "xibo_cms-xmr_1"
CMS web page can not load
Upgrading Xibo for Docker from 1.8.9 to 2.0.0 problem
Resizing images in playlist
XIBO 1.8.5 en mode cms - UBUNTU 16.04
Wget:unable to resolve host address 'xibosignage.com'
403 forbidden into modules
New 1.8 CMS on U16.04.04LTS/Docker
Centos 7 and xibo-docker-1.8.9 can't get to xibo application
Issues with XMR when importing old data
Linux vps or docker vps
Docker on multiple servers
VirtualHost on VPS for subdomain using docker
Docker read-only file system
