HTTPS on Docker Install with own SSL Cert
Installation Method
Docker
Operating System
Ubuntu Server
I have installed Xibo in docker, using the guide here: Xibo CMS with Docker on Ubuntu 22.04 - However, instead of LetsEncrypt, I have my own SSL cert I want to use, however, struggling to get this working with Apache, does anyone have a guide on this or can point be in the right direction?
Cheers!
Instead of configuring LetsEncrypt, you add your SSL certificate to Apache’s configuration as you would for any other Apache installation with an SSL certificate.
There’s multiple guides out there to configuring SSL on Apache. Broadly it’s something like this:
<VirtualHost *:443>
        ServerAdmin webmaster@localhost
        DocumentRoot /var/www/html
        ErrorLog ${APACHE_LOG_DIR}/error.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
        ProxyPreserveHost On
        RequestHeader set X-Forwarded-Proto expr=%{REQUEST_SCHEME}
        ProxyPass / http://127.0.0.1:8080/
        ProxyPassReverse / http://127.0.0.1:8080/
        SSLEngine on
        SSLCertificateFile /path/to/your_certificate.crt
        SSLCertificateKeyFile /path/to/your_private.key
        SSLCertificateChainFile /path/to/intermediate_bundle.crt
</VirtualHost>
Hi Alex
Thanks - I had thought that would be the case and is what I have done since, however, this now gives me the apache default page rather than the xibo login and still no SSL cert.
You’re likely missing the ProxyPass and ProxyPassReverse lines
