Hello everyone,
i have Ubuntu 16.04 with Xibo 1.8.2 and Docker running. Installed it with the help of:
Since some days its no longer working. Acually i cant login to the xibo site.
The only thing i get is a Error: connection failed.
So far i checked the following things:
- docker-composer is up and running
- restart server didnt helped
root@xibo-server:/opt/xibo# docker-compose logs
Attaching to xibo_cms-web_1, xibo_cms-xmr_1, xibo_cms-db_1
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-web_1 | MySQL started
cms-web_1 | DBVersion
cms-web_1 | 133
cms-web_1 | Configuring Backups
cms-web_1 | Running maintenance
cms-web_1 | Starting cron
cms-web_1 | AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 172.18.0.4. Set the ‘ServerName’ directive globally to suppress this message
cms-db_1 | 2017-11-15 10:07:41 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
cms-db_1 | 2017-11-15 10:07:41 0 [Note] mysqld (mysqld 5.6.37) starting as process 1 …
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
1a4325dd14f3 xibosignage/xibo-cms:release_1.8.2 “/entrypoint.sh” 9 minutes ago Up 9 minutes 0.0.0.0:80->80/tcp xibo_cms-web_1
bb36187e2f9f xibosignage/xibo-xmr:release_1.8.2 “/entrypoint.sh” 9 minutes ago Up 9 minutes 0.0.0.0:9505->9505/tcp, 50001/tcp xibo_cms-xmr_1
94eb5c9a0f92 mysql:5.6 “docker-entrypoint…” 9 minutes ago Up 9 minutes 3306/tcp xibo_cms-db_1
root@xibo-server:/opt/xibo# docker logs xibo_cms-db_1
The ufw firewall is disabled and should not cause any trouble.
Any further ideas whats wrong here?
best regards
