API Issues "error":0,"message":"API configuration problem
Hello, this is a new installation of Xibo 4.1 Docker on AWS [Ubuntu 22.04]
CMS Version: 4.1
Installation Method
Docker
Operating System
The operating system the CMS is installed on
We got, the following error when try to connect with API.
{“error”:0,“message”:“API configuration problem, consult your administrator”}
the following solutions did not work with me. please help:
We issued all keys required, but still same issues.
Hello @okkhalid and all
Just bumping this,
Exact same issue,
Similar setup,
Followed the same solutions
Trying to generate a token in postman like so
Screenshot 2024-10-15 092248
Exact same error : {“error”:0,“message”:“API configuration problem, consult your administrator”}
Logs don’t show any detailed error
Could it be this invalid key supplied? and if so where do I generate this key?
Thank you for your time,
I think it does not work with self hosted. we used docker to install and based on what I read, docker installation will setup the cerficates keys, for private, public and encryption.
no luck
