CMS Not resolving after following SSL guide
CMS Version: 4.0.11
Specify the full CMS version you are using, including the revision number.
Issue:
After following the guide here: https://community.xibo.org.uk/t/xibo-cms-with-docker-on-ubuntu-22-04/9392
I’m unable to resolve the server using the FQDN on http or https, but I can get in via local IP so I’m a little confused.
Here is my Apache Default Site conf (I Removed the rewrites from Certbot after noting that it wasn’t working):
Blockquote
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request’s Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
ServerName myddnsname.webhop.me
    ServerAdmin webmaster@localhost
    DocumentRoot /var/www/html
    # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
    # error, crit, alert, emerg.
    # It is also possible to configure the loglevel for particular
    # modules, e.g.
    #LogLevel info ssl:warn
    ErrorLog ${APACHE_LOG_DIR}/error.log
    CustomLog ${APACHE_LOG_DIR}/access.log combined
    # For most configuration files from conf-available/, which are
    # enabled or disabled at a global level, it is possible to
    # include a line for only one particular virtual host. For example the
    # following line enables the CGI configuration for this host only
    # after it has been globally disabled with "a2disconf".
    #Include conf-available/serve-cgi-bin.conf
    ProxyPreserveHost On
    RequestHeader set X-Forwarded-Proto expr=%{REQUEST_SCHEME}
    ProxyPass / http://127.0.0.1:8080/
    ProxyPassReverse / http://127.0.0.1:8080/
Here's the dockers ![image|690x103](upload://82vI5ZqxWarfDMFwaHcrZAts5Kv.png)
And my custom-ports.yml
version: “2.1”
services:
cms-db:
image: mysql:8.0
volumes:
- “./shared/db:/var/lib/mysql:Z”
restart: always
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_RANDOM_ROOT_PASSWORD=yes
mem_limit: 1g
env_file: config.env
cms-xmr:
image: Package xibo-xmr · GitHub
ports:
- “9505:9505”
restart: always
mem_limit: 256m
cms-web:
image: Package xibo-cms · GitHub
volumes:
- “./shared/cms/custom:/var/www/cms/custom:Z”
- “./shared/backup:/var/www/backup:Z”
- “./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z”
- “./shared/cms/library:/var/www/cms/library:Z”
- “./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z”
- “./shared/cms/ca-certs:/var/www/cms/ca-certs:Z”
restart: always
environment:
- MYSQL_HOST=cms-db
- XMR_HOST=cms-xmr
- CMS_USE_MEMCACHED=true
- MEMCACHED_HOST=cms-memcached
ports:
- “127.0.0.1:8080:80”
mem_limit: 1g
cms-memcached:
image: memcached:alpine
command: memcached -m 15
restart: always
mem_limit: 100M
cms-quickchart:
image: ianw/quickchart
restart: always
If I forward 443 to the server, then it works, however we need 443 for another machine, are there any workarounds?
I would use nginx setup as a reverse proxy and use the multiple upstream to handle multiple internal servers that need to run on a single external IP.
That way Nginx does all the ssl/tls offloading, makes your certificate renewals much easier and allows your applications to use their resources more efficiently.
Are you running xibo + whatever else on an office network or home network with a single external IP?
I use nginx for this as well as load balancing for years and it works very well.
Yes, Just hosting it from our HQ for some digital signage on our tills and eventually our TVS, I do plan on having a dedicated IP for it and an actual server as well.
