How can I run a SQL command when using a Docker Install?
While troubleshooting an issue you maybe asked to run a SQL statement on your database Docker container, or you may want to run a statement yourself for another purpose. To do either of these things there are two options.
  1. Using the command line
  2. Using the GUI called PhpMyAdmin
Command Line
Before you can run a statement inside the docker container you will need to find the container name. This can be done using the docker ps command.
The resulting output will show a list of running docker containers, one of these will be the web container. Depending on your folder name, that will look something like this:
CONTAINER ID        IMAGE                             COMMAND                  CREATED             STATUS              PORTS                               NAMES
28a6c69ec7be        xibosignage/xibo-cms:latest       "/entrypoint.sh"         2 weeks ago         Up 16 seconds       0.0.0.0:80->80/tcp                  xibocms_web_1
a8fdca5d77dd        xibosignage/xibo-xmr:latest       "/entrypoint.sh"         2 weeks ago         Up 17 seconds       0.0.0.0:9505->9505/tcp, 50001/tcp   xibocms_xmr_1
a21e1b4c6558        mysql:5.6                         "docker-entrypoint..."   6 weeks ago         Up 17 seconds       0.0.0.0:3315->3306/tcp              xibocms_db_1
You’re looking for the container name with web in the name - in the example above that is xibocms_web_1. Then, substitute name in the following:
docker exec -ti name bash
That will get you a shell inside the web container. To connect to MySQL, you’d then run
mysql -u cms -h mysql -p cms
The password will be the one you set in config.env when you installed Xibo.
Please avoid making direct changes to your data as we can’t offer support once you’ve done so. Many of the tables reference each other so it’s not safe to delete or modify things directly, unless you have been specifically asked to do so.
PhpMyAdmin
We can add PhpMyAdmin as an extra Docker container which can be started and stopped when you need to access the database.
You need two things. First, name of your MySQL container, which you can get by running docker ps as per the Command Line instructions above. You need the one with cms-db in the name. Second, you need the name of the network the MySQL container is running in, which you can get by running docker network ls
For example:
  • Container name: xibodocker_cms-db_1
  • Network name: xibodocker_default
You also need to pick a port for PHPMyAdmin to be available on, you can choose any available port number, I chose 8080 which would be suitable on most systems that are dedicated to Xibo.
You would then run a statement to create and run a docker container for PhpMyAdmin:
docker run --name phpmyadmin -d --network=xibodocker_default --link xibodocker_cms-db_1:db -p 8080:80 phpmyadmin/phpmyadmin
PHPMyAdmin will then be running on port 8080, and you would log in with the username cms and the password you picked in config.env.
When you’re done with PHPMyAdmin, you can simply run docker stop phpmyadmin to stop it temporarily (and then docker start phpmyadmin to start it again if needed later), or docker rm phpmyadmin to remove it completely.
Database username and password
Xibo 1.8.1 DB Details
Adding a table in the database
Xibo on Docker can't export the database
Problem in upgrading 1.7.9 to 1.8.1
249/5000 Mysql connection with machine call or root password
1.8 Docker Backup Not Current, Won't Run, Upgrading to 1.8.2
Is MyPhpAdmin installed from docker? + import questions
Connect phpMyAdmin no login account infos
Remote connection to Xibo MySQL DB
Upgrade from 1.8.2 to 1.8.3 (and from 1.8.0 rc1 and on and on...)
SENDFILE_MODE missing from Settings
Missing layouts
Displays lost authorization after update 1.8.12
Error when exporting
After update 3.0.0 - Calendar not showing all displays
Xibo Docker Login
Unexpected Error, please contact support error
Xibo 2.0.1 Layout not found and import layout not working
XiboWidgetNotificationView
Connection Refused after checking "Force HTTPS in CMS settings"
Schedules messed up after update to 1.8.6
Notification Widget and old thumbnails
Deleted admin users
New Layout Corrupting Existing Layout
Ativa FORCE HTTPS
High mysql cpu load
Docker installation doesn't start anymore
Latest news in dashboard
Xibo Docker upgrade problem
Forgot password
Xibo docker 1.8.9 to 1.8.11 stuck on Fix database constraints and indexes
CMS error - protocol violation
CMS white label in docker installation
Which cms file should a non docker download?
Install module button
LG WebOS device not available for a schedule layout
Xibo update 1.8.2 to 2.3.12: no daypart appears, it is empty
Data usage per Client >10MB/h?
The server committed a protocol violation. Section=ResponseStatusLine
How can I access database
Xibo CMS 3.2.0 Released
Fetch Remote Datasets task Exit: 0
Removing an image from library => Unexpected Error, please contact support
Cannot delete because DataSet is in use on one or more Layouts
Forgot Password 1.8.1 Docker
Xibo Docker 3.1.0 The CMS is temporarily off-line as an upgrade is in progress
Maintenance Running Long on Boot, Not Running on Schedule
Docker Ubuntu not reachable after reboot
Switch to docker
Cahnged the setting xibo 1.8.2 :forced HTTPS enable"
