API Problem after installation CMS 3.0.3
CMS 3.0.3
Installation Method
Customer Installation for IIS 10
Operating System
Windows Server 2019
Xibo Login works and i can create Layouts and so on, but with RestAPI i have a problem.
I try with Postman to access to Xibo, but this message came back, what say this message me?
“error”: 0,
“message”: “API configuration problem, consult your administrator”
i am also facing this same issue
{“error”:0,“message”:“API configuration problem, consult your administrator”}
I have the same issue (CMS Version 3.0.3 / IIS 10 / Windows Server 2019).
I dont know if the issue is releated to Someone can help to set up work with API (CMS version 3.0.0)? or not.
Guys, i was finally able to obtain a access_token!
What you have to do:
  1. Open the path of your library. There should be a folder called “certs”
  2. Inside this folder, create three new files:
  • encryption.key
  • private.key
  • public.key
  1. Go to Online RSA Key Generator and generate a keypair. Copy the contents to the corresponding file (Private Key = private.key, Public Key = public.key)
  2. Go to Generate free random base64 string +> GeneratePlus and generate a 32 bytes long base64-string. Copy your string to the file encryption.key.
  3. DONE!
Create in Postman under “Headers” a new key:
Key: Authorization
Value: Bearer
