We are pleased to announce release candidate 2 for the 4.0 version of Xibo. The codename for this version is “Westphal”.
20D/Westphal was a periodic comet with an orbital period of 61 years. It fits the classical definition of a Halley-type comet with (20 years < period < 200 years). It was originally discovered by the German astronomer J. G. Westphal on July 24, 1852.
4.0.0-rc2 is a development preview only and should not be used in production. We recommend testing this release with a fresh installation of Xibo.
Please note, due to an error during the release process, the release-4.0.0-rc2 Docker tag and release files report 4.0.0-rc1 as the version on login and about.
Earlier test releases working towards 4.0:
Feedback, Feedback, Feedback
This release candidate allows all users to test the v4 functionality we have included so far and provide feedback. This is a huge help to us in identifying bugs with new functionality or areas we ought to note for further improvement.
Feedback can be made in reply to this post where a member of the team will pick it up and ask for further details if required.
Download
This release requires PHP 8.1 or later. We also recommend MySQL 8.
Please use the links below to download this release:
- Xibo for Docker - Linux / Windows
- Xibo for Apache/Nginx / WAMP/IIS
You can also get a 14 day trial of v4.0.0-rc2 using Xibo’s Cloud hosting.
Players
The following beta test players are available to try with this release:
All latest v3 players (Android, Tizen, webOS and Windows) will communicate with a v4 CMS in legacy mode.
Changes
This release builds on the prior alpha/beta/rc releases, further refining the scheduling and layout editing experience.
- Commands: multiselect displays to run commands
- Dashboard: refresh the media manager dashboard with relevant information
- Layout Editor: group elements
- Layout Editor: pin/repeat data slots for elements
- Layout Editor: preview playlists on the canvas with previous/next arrows
- Widgets: dataset elements
- Widgets: mastodon username filter
- Widgets: PDF duration fixes
- Widgets: various fixes to static templates
- Various bug fixes
Content Synchronisation
The content synchronisation feature is available for beta testing on Android. The ideal configuration is a wired network connection, to the same physical switch, with identical devices. We hope to support different devices on networks which are “further apart” and will update these recommendations once we have further feedback.
We hope to bring this feature to webOS/Tizen and Windows players in due course.
Elements and “pin/repeat slot”
We have added an option to elements for pinning/repeating a data slot. Pinning a slot makes the first data item to appear in that slot stay there for the entire duration of that widget - it will not cycle with the others.
Repeating items to fill all data slots will ensure that you don’t have any empty slots in case you have 2 slots and 3 items (you will see items 1, 2 and then 3,1).
The pin slot options appears underneath the data slot:
And the repeat option can be found on the advanced tab.
Neither of these options are fully operational yet, and we will be updating them ahead of release.
4.0.0 is nearly here!
This will be our final release candidate before a stable release is available in due course!
