Webpage updating issue
Continuing the discussion from Webpage contents does not update:
Gino,
Could you tell me which config you made in IE? I´m facing the same issue.
I am fairly sure it’s in IE, Internet options, general tab, settings under browsing history -> Temporary Internet Files
Yes, indeed. I have made 2 screenshots. Make sure it is set to Every Time I visit the webpage.
And I switched OFF allow website caches. But I don’t think this is changing the behaviour of not showing the last updated page. The above setting does !
That’s perfect. Now it’s working like a charm.
Thank you, sirs!
Beto
