Using DataSets to display Birthday
I want to use the Datasets to display Birthdays of people.
How can I change the filter to display the birtdays of that day NOW()?
Continuing the discussion from Using DataSets to Display Meeting Room Bookings:
NOW() > Start AND NOW() < End
Assuming Start/End - are the day of someone’s birthday it should work. ie:
Start 2015-09-01 00:00:00
End 2015-09-01 23:59:59
Then with this filter it will show only record(s) of people that have birthday on that specific day.
As for dataSet you would need just dates and [Name] I guess, then in ticker add this filter and in appearance the [Name] tag.
Peter,
I use only one date and no time.
Date 2015-09-02`
Is there a filter option for NOW() to check only on the date.
Then I will have a filter like
NOW(??) = Date
Yeah I guess you can do something like that
Your Column with ‘Date’ in my example is named ‘Birthday’ it’s a column in date format and 2015-09-03 dates in rows so something like you already have.
Then in filter you can put something like this:
DAY(Birthday) = DAY(CURDATE()) AND MONTH(Birthday) = MONTH(CURDATE())
Where ‘Birthday’ is a column name with dates so you might want to change that if your column has different name
It should work just fine
Peter,
Great it works!! :grinning:
Thanxs
Cool :smile:
In this case, I’ll close this topic.
