Layout and Scheduling problems
Hi I have a scheduled layout than is not playing, but if I set the same layout as default playing.
XIBO cms 1.7.4 player android r59
Player android minix z64 same problem with other…
perhaps date/time settings in CMS and/or on device are wrong?
Therefore default layout will be displayed, but schedule won’t work since time on CMS and device doesn’t match
Hi Peter, date/time settings are correct.
Could you schedule something on your display, wait till it will receive schedule information and show me the status window on your device please?
now I will upload export layout to my ftp site and i will send you a link
So it is currently displaying your default layout (4)
and your scheduled layout will be displayed on 23:55.
So unless you scheduled it like that, it seems like date/time on server/cms and device is not quite right.
There were some issues with schedule time in earlier CMS versions, perhaps consider CMS upgrade to 1.7.6
Peter, layout scheduled is 50 but monitor shows 4 that is default.
Next 2016-02-18 23:55 because I have that schedulation time 18 02 2016 - 00:00 to 18 02 2016 - 23:55 and repeted every day .
Layout set as default play on monitor.
as I said in earlier CMS versions there were issues with schedule/download time especially regarding 00:00 (midnight).
Either consider update to 1.7.6.
Or change your schedule a little, since you want your scheduled layout to play pretty much all the time.
I would suggest for example:
Start time 17.02.2016 8:00
End Time 30.09.2016 23:50 (basically some date far into the future)
without repeats
I’d suggest this kind of schedule no matter if you will upgrade CMS or not.
Peter I did what you suggested me but layout scheduled doesn’t start and default layout is showed.
So if you deleted the previous event (with repeats) and only the one that I suggested is currently scheduled and your player is up-to date (ie knows about new schedule) it should work (unless you have some really long durations on your default layout).
You might want to close Xibo and reopen it, it will force connection to the CMS.
It should work, but it doesn’t works…
Now I changed the scheduled layout with other more simple, and it works.
The status now is:
look scheduled Layout is 64 and 4 is default and player works with 64.
but if I scheduled 50 this is status:
scheduled Layout is 4 and 4 is default and player works with 4 but really 50 is scheduled.
In that case, it probably would be good if I could have a look at your layout (50),
Please upload it somewhere and share the download link we me (here or via pm)
Edit: Are there any errors under ‘last 5 log message’ on status window?
I will send you a link as soon as possible file zip is 300MB and ftp is very slow…
Remember this layout as default works
Peter thank you for your support.
LINK:
http://www.dsdatasi.it/FILES/export_htv-bar-dei-pini.zip
Thank you.
I downloaded and scheduled your layout on my device, it downloaded all the necessary content and started to display your layout.
I think there is still some issue with .avi videos on it (as I mentioned in your other topic).
I am not sure why it doesn’t work for you (if scheduled).
Looking at your status screens, with layout 64, on your device it was 32/32
with layout 50 it’s 67/ (67?) - so it had to download the files, I assume it finished it since it’s up-to date.
Although it seems odd that it had to download those files, since you said it was set as a default and was displayed before this test.
Since your other simple layout was working when scheduled, I assumed that your default layout does not have any long durations? If it does, then that can delay scheduled content.
Could you perhaps enable global debugging (CMS-> report fault page) and auditing for this display (CMS->displays page-> edit you display -> advanced tab).
Schedule this layout and see if there are any errors that could explain it?
Other than all that, you might still consider update to 1.7.6
Peter for few second the status player shows this message:
any idea?
dependence 236???
is a file, media or what?
most likely a file in CMS library with id 236.
Is file with this id currently in your CMS (or was it deleted?) and assigned to your layout?
So it’s the same error as here Method: schedule manager: message invalid dependent for layout - layout12falsefalse (timestamp stuff) dependent = 254.mp
Although it seems odd in your case.
Could you try (on z64 since I know it should work) switching to public storage?
In Xibo app -> settings -> tick "Use Public Storage?“
and select first option under 'Storage Options”
It will force the device to download layout’s content again.
Hi Peter,
I’ve done all the tests that you suggested.
I have not updated cms, but soon I will.
I tried all the videos in a single playlist, and they work.
if I delete one any video from the play list, the play list works
so 35 videos not work 34 work.
Player is 73% of storage
Memory Limit 512MB
Memory Allocation 23 MB
it does not work in a critical condition
Is there a limit on the number of files?
The playlist that I sent to you, with your player work?
thanks
Andrea
There is no hard limit for number of files on a layout.
It does work, ie it’s displayed, but I think my z64 doesn’t really like your .avi videos very much.
I’d say again that converting your videos to mp4 H264 encoded and updating the CMS could only help you.
Although I agree that it seems a bit odd that it doesn’t work with 35 items and works with 34
