Hi
In my settings i did forced HTTPS enable .
Now i cant access my CMS.
How to set it back
Hi
How to set it back
I presume you don’t have an HTTPS connection and so now it’s redirecting you to port 443, and effectively you’re locked out?
If so, you need to run the following SQL:
UPDATE `setting` set value="0" where `setting`="FORCE_HTTPS";
Then delete the contents of the cache folder in the CMS library
shared/cms/library/cache/*
Do not remove the cache folder itself - just the files/folders contained in it.
If you’re running with Docker, instructions on how to connect to MySQL are here:
