We have a new revision of the Linux Player in the BETA channel ready for testing. This version of the Player attempts to fix the Video memory leak issues we’ve encountered with the Player to-date. This revision should also be hardware accelerated.
Please refresh your snap from an already working Player such as the previous stable or beta channel release.
Good afternoon, after the update, try for 24 hours and there is no memory loss.
What happens to me is that from yesterday to today, proof of play stopped reporting.
I have statistics from 03/03/2020, I wanted to consult recently but I can not report, the only thing that changed was the version of the player.
does anyone else happen to him?
We tested yesterday with a small playlist and memory appeared to be stable. This morning we tested with a very large playlist (which is normal for us) and it crept up to over 70% memory utilization and started hanging. We’re doing some more testing and will report back here.
good morning.
I am still testing the 46 Beta version, it is playing well, it has no flaws with respect to the previous ones.
What I do notice is that after the end of the playback and it starts again, it is paused and the console appears with information (attached image).
It’s a few seconds and starts playing again.
I hope it is helpful, any query to the orders.
I just checked our test system. Normally I’ve seen a good deal of terminal output but now I’m not seeing any whatsoever. So - no Gdk error… but then again, no output at all.
Thanks for the response - the Gdk error would have output no matter what error log levels you have set (which might be why you’re not seeing terminal output).
