Have you looked into the possiblility or running both 5.6 and 7 at the same time? Some configurations can support this.
I can’t answer the question as to if Xibo is closer to running on php 7 or not, as I am not part of the development team. I think the main problem is dependencies. As dependencies support php 7 Xibo then will in turn also be able to support php 7.
1.7 is never going to run on PHP7. There’s too much that would require change to support it.
1.8 will, but at this time, some of the libraries that 1.8 uses are still not supporting PHP7, so we will have to wait for them to get fixes in place before our code can run there.
In the interim, you could consider running 1.8 series in Docker containers on your machine.
Downloaded the 1.8 beta from Github… just the source…
The main directory did not contain an index.php and I tried to get “cute”… but it all turned
into a train wreck ( to mix metaphors )
I saw the docker stuff… My feeling was it force Xibo to run on port 80 and trash my intranet site ?
i.e. sort of designed to run on virgin hardware…
Does the docker isolate xibo from the underlying php ?
I was running Xibo as an apache alias http://intranet/Xibo
But these are all newb questions…
Certainly willing to have a go if you can point me in the right direction.
1.8 is one of the newer style of PHP applications - where there’s a “web” directory, which contains index.php, and that is the point that the webserver must serve as your document root. The directories below that need to remain there, but they aren’t web servable. This greatly increases security since library code isn’t exposed to the network.
If you download the source yourself from Github then there’s a load of work that has to be done to bring in application dependencies. You’re much better off downloading a release tarball as it has all that work done for you.
Yes Docker brings its own PHP environment - everything Xibo needs to run pre-configured for you.
By default it runs on port 80, but you can configure launcher to bring it up on any port you want. Once you’ve done that, you can either address it directly on that port, or you can setup your main Apache instance to proxy through traffic to it.
When we’re closer to the final 1.8 release, you can expect some documentation on setting up a Docker based setup and migrating a 1.7 series install over to it. launcher doesn’t support a migration at this time.
1.8 won’t work with PHP 7 as it stands, so I’d say you need to wait for us to announce support for that
The reason the URL isn’t found is your AllowOverride None line
It’s preventing the .htaccess file we ship using mod_rewrite to handle URL rewriting.
The Docker image comes with all this preconfigured. If you want to try and do an upgrade, then your settings.php will need to go in, but under the web directory. I’d guess it’s erroring because of the libraries in the stack that don’t support PHP 7.
Perhaps in the interim, you’d be better spinning up a new server with an older Ubuntu version to host Xibo 1.7.9 on until you have something else in place.
had a play with docker… very Interesting … but it seems to want to install php5 and a whole bunch of other stuff duplicatiing what was already on my (production) server… and I had issues with the gpg on a virtual machine and it all got a bit scary and hard.
Took your advice and cranked up a spare box with Ubuntu 14.04.
