Hello, I want to set up a text that will change every hour on the same layout. Is this possible?
Hi
Yes its possible.
You can do it with Datasets.
Here is a Howtow how it works:
So, if you implementet that, you can give a dataset with an Text a Starttime and an Endtime.
Example: 10:00 till 11:00 = Text 1 11:00 till 12:00 Text and so on…
system
Closed
3
