Syntax error unexpected token
Please, help.
Every file over 10Mb i get this messade. I have change all parameter in php.ini. File_size etc etc
Is it 1.7.8 CMS?
Did you make all necessary changes in php.ini? How do I upload files bigger than 2MB / How can I increase the upload file size limit?
and restarted your web server?
No. 1.7.6
Made every change :slight_smile:
[13-Sep-2016 13:54:25 Europe/Paris] PHP Warning: POST Content-Length of 21385980 bytes exceeds the limit of 20971520 bytes in Unknown on line 0
i’m confused, something is wrong in my .ini i think…
[13-Sep-2016 13:47:40 UTC] PHP Warning: PHP Startup: in Unknown on line 0
[13-Sep-2016 13:47:41 UTC] PHP Warning: PHP Startup: in Unknown on line 0
[13-Sep-2016 15:48:09 Europe/Paris] PHP Warning: POST Content-Length of 21385980 bytes exceeds the limit of 20971520 bytes in Unknown on line 0
I soon give up , have changed in php.ini both in apache and php directory.
Restarted , screaming and crying.
Do I need to stream video from youtube to make it work = )
php 5.5.12 I use
