String data, right truncarted: Data too long for column 'lastRunMessage' at row 1
Task Regular Maintenance shows error and never gets executed again.
Error:
Task run error for taskId 2. E = SQLSTATE[22001]: String data, right truncated: 1406 Data too long for column ‘lastRunMessage’ at row 1
Setup:
docker, Xibo Version 3.0.3
Looks kind of related to Fetch Remote Datasets task Exit: 0
Different task but same error! Hope Xibo people can help :slight_smile:
Also have a problem with wake on lan (WOL).
If I wake up a screen manually via the web interface it works, but the stored schedule does not.
In the schedule is stored that the display should be woken up at 7 o’clock, but unfortunately this command is not executed.
Does this also have something to do with the maintenance task?
