Downgrade 3.0.4 to 2.3.12
I do like to downgrade from 3.0.4 to 2.3.12 as we have a problem with de “Fetch remote datasets” task (see Fetch Remote Datasets task Exit: 0 and String data, right truncarted: Data too long for column ‘lastRunMessage’ at row 1) and I do not know how to debug/resolve this issue.
Is downgrading even possible, if so, how?
Of course I prefer to solve the issue but as long as it’s there it is causing critical displays to show the No Data template and that’s not acceptable.
I realized :slight_smile: that we have 2 other test environments (v3.0.3 and 2.3.12) working without problems for some time. I will upgrade the 3.0.3 version to 3.0.4 to see if the error will occur there as well.
Running 3.0.4; the task has been running without problems for more then a week now. Nothing changed, but I’m glad things are ok now. Still a bit worried it might come back again… :slight_smile:
