Schedule is not showing any events although there are some
Hello all,
I have very strange issues with newly installed xibo instance. It was just Xibo installation, not a Docker image.
  1. No events are shown in Schedule calendar page, although displays are selected. Layouts are correctly assigned and they are visible on the screens. This is critical, because there is no way to remove already scheduled layout … workaround are also appreciate as a short term solution.
    Image: https://ibb.co/wcYMBbb
Console output:
SITEDOMAIN/web/dist/vendor/bootstrap-datetimepicker/js/bootstrap-datetimepicker.min.js net::ERR_ABORTED 404 (Not Found)
jquery.js:3850 Uncaught TypeError: $(…).datetimepicker is not a function
  1. Displays are not visible on “Schedule Event” page.
    Image: https://ibb.co/HtWChbk
Hi mig.kus!
I have replied about those issue in your second thread but basically it would come from the fact that your CMS that it has not been properly installed because you shouldn’t have /web in the CMS address,(as shown in second thread). When you do it causes all sorts of odd issues such as what you described.
Please consult both following guides to re-install the CMS correctly : https://xibo.org.uk/docs/setup/prepare-your-environment and https://xibo.org.uk/docs/setup/cms-installation-guides
