I am trying to upload video file but after uploading it shows message that resource temporarily unavailable. I cant find it in the library and cant assign it. Video file size is 125MB. My server allow file upload up-to the size of 1GB.
We’re happy to help, but you will need to be a little patient as this is a community site! If you want commercial support then that is available, please email support@springsignage.com
It looks to me like something on your web server is causing the PHP process to crash unexpectedly - what exactly causes that is difficult to comment on without seeing your web server error logs for the same period. I do not mean the Xibo logs - I mean the actual web server logs (I do not believe this is a Xibo problem, I think it is upstream).
I noticed that some of the files which were more than 120MB were put into Xibo Library’s Temp folder. It means Xibo was able to download the file but for some reason putted them into Temp folder.
