The issue was solved in february but, yesterday, the same message came out (There is an error in the XML document (0,0) with the path to the file xibo client config).
I have 2 questions :
Why did it happen again ?
The way to solve it is to open Xibo player options and write down the informations about CMS / key / local library, am I right ? This will recreate the file “xibo client config” ?
