Linux Player not Pulling layouts
Specify the full version you are using including the revision number.
version 1.8-R6
code version - 108
I have installed the docker version of the CMS and i am using the linux player.
When creating a layout the player only pulls the background colour of the layout and does not pull any text or widgets. the console on the player gives me these errors but i cannot find where to fix them
I have remove http from the start of the links as unable to share links
** Message: 09:38:25.178: console message: localhost:9696/bundle.min.js @2: ReferenceError: Can’t find variable: Handlebars
** Message: 09:38:25.179: console message: localhost:9696/bundle.min.js @2: TypeError: Attempted to assign to readonly property.
** Message: 09:38:34.921: console message: localhost:9696/bundle.min.js @2: TypeError: Attempted to assign to readonly property.
** Message: 09:38:34.987: console message: localhost:9696/bundle.min.js @2: TypeError: Attempted to assign to readonly property.
** Message: 09:38:34.988: console message: localhost:9696/5.html @213: SyntaxError: Unexpected identifier ‘firstRun’
** Message: 09:38:35.030: console message: localhost:9696/bundle.min.js @2: Called onInitialize for widget >
** Message: 09:38:35.031: console message: localhost:9696/bundle.min.js @2: Non-data Widget::Module
** Message: 09:38:35.032: console message: localhost:9696/bundle.min.js @2: jQuery.Deferred exception: Attempted to assign to readonly property.
** Message: 09:38:35.033: console message: localhost:9696/bundle.min.js @2: Non-data Widget::Global Elements
** Message: 09:38:35.035: console message: localhost:9696/bundle.min.js @2: jQuery.Deferred exception: Can’t find variable: Handlebars
** Message: 09:38:35.128: console message: localhost:9696/bundle.min.js @2: TypeError: Attempted to assign to readonly property.
** Message: 09:38:35.129: console message: localhost:9696/5.html @213: SyntaxError: Unexpected identifier ‘firstRun’
** Message: 09:38:35.188: console message: localhost:9696/bundle.min.js @2: TypeError: Attempted to assign to readonly property.
** Message: 09:38:35.212: console message: localhost:9696/bundle.min.js @2: Non-data Widget::Global Elements
** Message: 09:38:35.213: console message: localhost:9696/bundle.min.js @2: jQuery.Deferred exception: Can’t find variable: Handlebars
** Message: 09:38:35.218: console message: localhost:9696/bundle.min.js @2: Called onInitialize for widget >
** Message: 09:38:35.218: console message: localhost:9696/bundle.min.js @2: Non-data Widget::Module
** Message: 09:38:35.221: console message: localhost:9696/bundle.min.js @2: jQuery.Deferred exception: Attempted to assign to readonly property.
** Message: 09:38:35.223: console message: localhost:9696/bundle.min.js @2: ReferenceError: Can’t find variable: Handlebars
** Message: 09:38:35.223: console message: localhost:9696/bundle.min.js @2: TypeError: Attempted to assign to readonly property.
Xibo Team, do you see this in 06.2026 ?
For beta test player use:
snap install –channel=edge xibo-player
I followed this guide for the CMS Xibo CMS with Docker on Ubuntu 22.04 - Xibo Knowledge Base / The Xibo CMS - Xibo Community
And used snap install –channel=edge xibo-player for the player
Latest beta is 4.0.5, 1.8 is abandonwared since 2022
