Interactive Action Guide: need to be patched and updated
CMS4.3.0
Android
Version 4 - Code Version: 406
I’ve followed instruction from this guide: https://community.xibo.org.uk/t/interactive-action-guide-send-trigger-code-from-one-player-to-another/27947.
This guide should be updated considering new improvement done in version 4.3.0 that are not intuitive as you may expected, at least for me :grinning_face: .
The troubles begin in Command creation that I did following the screenshot from the guide:
This is my form just before save it:
Then I saved it and push “Edit” and the form have a couple of lines in “Header” section:
At the beginning I can think it’s fine: could be some staff added automatically by Xibo to make it works. But if I save the command and push Edit again it appear like this:
Clearly there is something wrong here.
Could you have a look?
Thank you, bye.
Thank you for posting. Our dev team have looked into this and identified a bug. Here is the created issue which you can track using this link: Command: HTTP trigger command adds extra headers after edit · Issue #3735 · xibosignage/xibo · GitHub
Thanks again.
