Hi
I am using xibo 1.7 cms and android player .
if u check the player it is showing a “!” messages and saying “display is outdated but not yet checked”
what it means
Hi
what it means
What version exactly are you using?
1.7.7 (CMS) and 1.7 R60(Android)?
[!] = Player wasn’t logged in since the content change.
So when it does log in and will be able to reach your CMS, it will need to download new/updated content/schedule and then it will change its status to checkmark.
If it is logged in and [!] status persists, could you please show us a screenshot of status window on your client?
so it seems that your device is not currently logged in to the CMS.
Could you please show us a screenshot of status window on it? Getting the Player Status
it should explain why it has some problems.
that seems like a connection issue, your device can’t reach your CMS (at least from time to time) and it is causing problems.
You might want to adjust the collection interval setting (display settings -> edit display profile) perhaps more frequent connection attempts will help here - although if there is some kind of issue with your network in general, then that would be the first thing to look at.
Solved thanks.It was some network issue .
Also do u have any recomentation for HDMI to rtsp streamer for live
