How to sync campain (or how to add layout to playlist...)
Android
v4 R408
Hi everyone,
I’d like to ask how to synchronise a Campaign playback across multiple Players.
Currently, I have several Layouts grouped inside a single Campaign (for example: a PDF with a Clock widget, a Webpage with a Clock widget, another Layout with text, data from a DataSet and a Clock widget, etc.).
I carefully went through the tutorial on Synchronised Events and Sync Groups:
However, it doesn’t mention anything about synchronising a Campaign. As I understand it, I can synchronise a specific Layout (or a Playlist embedded within a Layout), but not the Campaign itself.
I also tried approaching this from another angle — I thought about adding my Layouts into a Playlist instead — but I don’t see an option to add entire Layouts to a Playlist either.
What is the correct way to synchronise the playback of multiple Layouts across several Players?
Thanks in advance for your help!
