Hi Alex,
After few working days now I am getting this error “Fatal Error - sorry this shouldn’t happen. SQLSTATE[HY000] [1130] Host ‘172.19.0.4’ is not allowed to connect to this MySQL server”
This is output of command “docker ps -a”
CONTAINER ID IMAGE COMMAND CREATED STATUS
PORTS NAMES
ee0fd69db9f0 xibosignage/xibo-cms:release-2.1.2 “/entrypoint.sh” 8 minutes ago Up 5 minutes
0.0.0.0:80->80/tcp xibo_cms-web_1
427252796d1d xibosignage/xibo-xmr:release-0.7 “/entrypoint.sh” 8 minutes ago Up 6 minutes
0.0.0.0:9505->9505/tcp, 50001/tcp xibo_cms-xmr_1
4f5dc2b0638b mysql:5.6 “docker-entrypoint.s” 8 minutes ago Up 6 minutes
3306/tcp xibo_cms-db_1
72de972ba423 hello-world “/hello” 2 hours ago Exited (0) 2 hours
ago hungry_johnson
40b6001b7f87 hello-world “/hello” 3 days ago Exited (0) 3 days
ago eloquent_cori
This is output of command “docker-compose logs” after “docker-compose down” and “docker-compose up -d”
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-web_1 | MySQL started
cms-web_1 | ERROR 1130 (HY000): Host ‘172.19.0.4’ is not allowed to connect to this MySQL server
cms-web_1 | New install
cms-web_1 | Provisioning Database
cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2
cms-web_1 |
cms-web_1 | using config file .varwwwcmsphinx.php
cms-web_1 | using config parser php
cms-web_1 | using migration paths
cms-web_1 | - /var/www/cms/db/migrations
cms-web_1 | warning no environment specified, defaulting to: production
cms-web_1 | using adapter mysql
cms-web_1 | using database cms
cms-web_1 |
cms-web_1 |
cms-db_1 | 2019-11-08 13:05:22+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.6.46-1debian9 started.
cms-db_1 | 2019-11-08 13:05:24+00:00 [Note] [Entrypoint]: Switching to dedicated user ‘mysql’
cms-db_1 | 2019-11-08 13:05:25+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.6.46-1debian9 started.
cms-db_1 | 2019-11-08 13:05:29 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_
defaults_for_timestamp server option (see documentation for more details).
cms-db_1 | 2019-11-08 13:05:29 0 [Note] mysqld (mysqld 5.6.46) starting as process 1 …
cms-db_1 | 2019-11-08 13:05:29 1 [Note] Plugin ‘FEDERATED’ is disabled.
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Using atomics to ref count buffer pool pages
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: The InnoDB memory heap is disabled
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Memory barrier is not used
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Compressed tables use zlib 1.2.11
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Using Linux native AIO
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Not using CPU crc32 instructions
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Completed initialization of buffer pool
cms-db_1 | 2019-11-08 13:05:29 1 [Note] InnoDB: Highest supported file format is Barracuda.
cms-db_1 | 2019-11-08 13:05:30 1 [Note] InnoDB: 128 rollback segment(s) are active.
cms-db_1 | 2019-11-08 13:05:30 1 [Note] InnoDB: Waiting for purge to start
cms-db_1 | 2019-11-08 13:05:30 1 [Note] InnoDB: 5.6.46 started; log sequence number 1626027
cms-db_1 | 2019-11-08 13:05:30 1 [Note] RSA private key file not found: /var/lib/mysql//private_key.pem. Some authenti
cation plugins will not work.
cms-db_1 | 2019-11-08 13:05:30 1 [Note] RSA public key file not found: /var/lib/mysql//public_key.pem. Some authentica
cms-db_1 | 2019-11-08 13:05:30 1 [Note] Server hostname (bind-address): ‘*’; port: 3306
cms-db_1 | 2019-11-08 13:05:30 1 [Note] IPv6 is available.
cms-db_1 | 2019-11-08 13:05:30 1 [Note] - ‘::’ resolves to ‘::’;
cms-db_1 | 2019-11-08 13:05:30 1 [Note] Server socket created on IP: ‘::’.
cms-db_1 | 2019-11-08 13:05:30 1 [Warning] Insecure configuration for --pid-file: Location ‘/var/run/mysqld’ in the pa
th is accessible to all OS users. Consider choosing a different directory.
cms-db_1 | 2019-11-08 13:05:30 1 [Warning] ‘user’ entry ‘root@2b050af89174’ ignored in --skip-name-resolve mode.
cms-db_1 | 2019-11-08 13:05:30 1 [Warning] ‘user’ entry ‘@2b050af89174’ ignored in --skip-name-resolve mode.
cms-db_1 | 2019-11-08 13:05:30 1 [Warning] ‘proxies_priv’ entry ‘@ root@2b050af89174’ ignored in --skip-name-resolve m
ode.
cms-db_1 | 2019-11-08 13:05:30 1 [Note] Event Scheduler: Loaded 0 events
cms-web_1 | [InvalidArgumentException]
cms-db_1 | 2019-11-08 13:05:30 1 [Note] mysqld: ready for connections.
cms-web_1 | There was a problem connecting to the database: SQLSTATE[HY000] [1130] Host
cms-web_1 | ‘172.19.0.4’ is not allowed to connect to this MySQL server
cms-db_1 | Version: ‘5.6.46’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 MySQL Community Server (GPL)
cms-web_1 |
cms-web_1 |
cms-web_1 | migrate [-c|–configuration CONFIGURATION] [-p|–parser PARSER] [-e|–environment ENVIRONMENT] [-t|–target
TARGET] [-d|–date DATE] [-x|–dry-run]
cms-web_1 |
cms-web_1 | Configuring Database Settings
cms-web_1 | Setting up Maintenance
cms-web_1 | Protected Maintenance
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/*.pem’: No such file or directory
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/*.crt’: No such file or directory
cms-web_1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
cms-web_1 | Removing web/install/index.php from production container
cms-web_1 | Starting cron
cms-web_1 | AH00558: httpd: Could not reliably determine the server’s fully qualified domain name, using 172.19.0.4. Se
t the ‘ServerName’ directive globally to suppress this message
PS C:\xibo>
I am always getting this error.
Please help
