I get an error when I’m exporting a database or more like page is not found
"Not Found
The requested URL /xibo/index.php was not found on this server.
Apache/2.4.33 (Unix) Server at -IP- Port 80"
Also I’m not sure how this needs to be set up.
Please note: The folder location for mysqldump must be available in your path environment variable for this to work and the php exec command must be enabled.
You’re much better off running a mysqldump directly from the command line. I believe we’ve removed the export button in a future release on that basis.
Ps. Are there any tricks to run Xibo on a subdomain that points to different IP than the main domain?
I’m planing to use Cloudflare as a DNS. I don’t really need caching and CND functions but I use it as an extra layer of security.
You can backup the whole directory if you want, but the contents of shared/db are the live database files, and they need to be in a consistent state (ie the cms-db container stopped) for the backup to be usable. In general, you won’t be able to restore that directory and have the containers just work - you’d need to import the database from a backup file rather than just restoring the live database files.
I’m not sure I follow your question. My understanding is CloudFlare inject a holding page when you first access the website. The Players won’t like that behaviour, but should be resilient to it. It may prevent them updating when that is happening therefore.
