Jerry
1
I am running Xibo on Docker on a Ubuntu 16.04 virtual machine.
After running a “apt-get upgrade” and a reboot, my docker containers seem to be up and running, however I’m not able to connect to my webinterface.
All 3 containers seem to be running fine, but I’m to new to docker to verify if everything is ok.
When I run “docker ps”, I can see all 3 containers are running.
Does someone have any ideas on where to start looking for the problem?
Thank you.
alex
2
From your installation directory, run:
docker-compose logs
Does that show any errors or issues?
Jerry
3
I tried that and I only see some warnings on cms-db_1:
[Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option
However, it also states:
MySQL started.
Everything else seems fine.
alex
4
What do the logs from the CMS web container show?
docker-compose logs cms-web
Jerry
5
The logs:
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-web_1 | MySQL started
cms-web_1 | DBVersion
cms-web_1 | 133
cms-web_1 | Configuring Backups
cms-web_1 | Running maintenance
alex
6
So it’s running maintenance currently. When that finishes, the CMS web interface will be available.
We’ve seen a couple of issues that can cause maintenance running to take a long time (it should take a couple of seconds normally).
Was this a database imported in to Docker from a 1.7 install or 1.8 custom install?
Jerry
7
The database was imported from 1.7.
I allready had some problems with xmr but thought I solved it.
alex
8
In that case then, it’s likely that the XMR configuration is wrong and that will need to be adjusted as follows:
To correct it, connect to the MySQL container and then run the following SQL:
UPDATE `setting` set `value`='tcp://cms-xmr:50001' where `setting`='XMR_ADDRESS';
Then exit out, delete the CMS cache directory at shared/cms/library/cache, and then restart the containers.
Instructions for connecting to MySQL to run that command here:
Jerry
9
Wow! I did what you told me and it worked flawlessly
Thank you so much.
This settings also solved my problem with my xmr connection. I now get my screenshots back and my test player accepts commands.
