Moved and reconfigured server. Now running CentOS with Docker.
Have setup docker and it is running correctly in /opt/folder.
when i setup virtual host i get a error 503. only way working right now is apache is removed from CentOS.
Do I need to remove the xibo docker, install apache and then setup the xibo docker back up ?
Have 3 more docker sites need to setup …
