Hi there !
After almost a year without any problem on displaying what i wanted with Xibo, I wanted to operate a few changes on the layouts. Problem is that now, I’m back to where I started except the problem won’t go away on it’s own this time…
I’m using the 1.7.5 version and have a good internet connection.
I have two main problem leading to my campaigns not showing on my display (i think they are anyway) :
1 - The display doesn’t appear as being “Logged In” on the Displays page. It has a cross under it. I tried deleting the display and reinstalling it, it worked for a few minutes and the cross came back again…
2 - My Xibo Player Option does’t want to connect to CMS. Either it says “Maximum execution time of 30 seconds exceeded” There was an error during asynchronous processing. Unique state object is required for multiple asynchronous simultaneous operations to be outstanding."…
Is there a link between the 2 problems ? The error log doesn’t show anything specific that could help. I don’t understand why it’s not working anymore when I only added a layout to my campaign and didn’t touch any of the other settings…
Thanks for your help, and Merry Christmas !
