I cannot get one of my displays to show up in the CMS. one is working fine with exactly the same setup. I can connect using teamviewer, so the connections is not the issue. and the Xibo player options are set exactly the same as the working one. When i click save in player option it says the display is working but will not show in CMS.
I would guess the machine is a clone of the other one?
Try changing the hardware key for one of them, tell it to connect again. I think that should solve the issue.
Great work! This worked perfectly.
