Hello together,
can i copy an layout to an other client? wenn yes, how can i do this process?
For your answer its all right
thanks
Hello together,
thanks
If you mean copy a layout to another CMS you can. You Export it on the first and Import it again on the second. Both happen from the Layouts page.
If you mean can you schedule a layout on more than one Player - yes you can. You simply select multiple displays when you schedule the event.
i found a process in layouts âŚthere is standing âexportâ . but when i export the file the file is a .zip!!
in layouts you can import a file but i don´t know how its in .zip�? now
when i unzipping the file a have much mor files???
sorry can you helb me please!
You just import the zip. You donât need to do anything else.
This is only to copy a layout from one Xibo instance to another. If youâre copying within the same CMS you can just use the Copy layout feature to make a duplicate.
Hi alex, when i export for example a zip file and this file is 48 MB big and i copying to an usb stick⌠And with this usb stick i import the zip file to another cms not the same cms, it will not going
There is coming a message. I have to take a photo an put it here ok.
Markus
EDIT: Following text is comming down whilw i will upload the .zip file:
Please make sure that you have selected a file and it is ready uploaded
and then nothing else doingâŚ
What is here wrong?
Alex, kann you test it with one of yours please an can you tell me
Thanks a lot
You go to the Layouts page of the CMS, click Import and then select your zip file.
It will then upload it and add it to the system. If the new CMS wonât allow a 48MB zip file upload then itâs incorrectly configured. You need to follow the instructions in the CMS Post-Installation guide to get that CMS configured correctly for large file uploads:
https://community.xibo.org.uk/t/xibo-cms-post-installation-setup-guide/522
Hello Alex, thanks for your answer, but how can i see a mistake in the copy layout?
Can you copying your layouts in zip file to an other CMS?
The manual i donât understand. The answer is comming wgen i will copy thr zip file is not correct⌠Right?
How long does an 48 MB file to copying and where can i see that the layout is wrong?
Can the change the size of the file even later after installation? If yes how?
Markus
The layout export/import is specifically designed to copy a layout from one CMS to another. Itâs the only way to transfer a layout.
Importing an exported layout is as simple as uploading the complete unmodified zip file you exported from the original CMS.
If it wonât upload, then you likely havenât configured PHP correctly. The instructions for doing that are in the link I sent earlier.
Hi alex, what is centos 6??
Ok then i musst create always an new layout. Sorry, but i donât know ho i configurated a right php???
But always thanks for your help
I canât find a thread here in the forum. Can it be that iâm the one who has this problem??
Centos is a Linux distrubution
The problem is that youâre giving us no details. You just say âIt doesnât workâ. No screenshots of what youâre seeing or any error messages. We canât help you on that basis Iâm afraid. You need to give as much detail as possible.
Hi alex, i make at evenibg screenshots and put it here. Then you can see the mistake
Markus
Hi alex, look st the screenshot an the red answer below:
Please make sure that you have selected a file and its ready to upload
Although i have the file selected above already as an zip file! And this red message comed then i press the imort button!!
Are you allowing the file to upload completely before you press import? Judging by the 30% complete marker on the Firefox icon in the system tray Iâd say youâre not waiting for the file to upload before you click Import.
Hi alex, where is that standing with âallowedâ? Sorry, i click on export and then import⌠More not. No the 30% in Firefox was an another download. I wait till the download is fonished. It will be always coming the same infođ the last chanr is the allowed info. Please, you have to say where i can set it.
Where can i find the allowedsettings?
Markus
You need to wait for the upload to finish before you click Import. Thatâs all there is to it.
You select the file you want to upload (the zip file).
Once selected, wait until it says the upload has completed like this:
Then you can click Import.
Hi and where can i allowed the option??
And where can i see when i have choosen the file that itâs uploaded?
Youâre making this so much harder than it is.
You go to Import. You pick the zip file that you exported from your other CMS. You wait for it to tell you the file uploaded, and then you click Import.
Thereâs nothing to set, change, allow or anything else. You just upload the file you already exported (the zip file).
Sorry i can unsderstand you but i have token it you say⌠I pick up the zip file and waitâŚwaitâŚwait ⌠You can see it on the screen. Normally is cames s text : file are uploaded and then i can push the import button⌠Nothing is doing
Ahhhh NOW it has to be O.K.!! i have token a 1,9 MB big file an after 2 Minutes there was standig"The file is uploaded"
O.K. the other file has 52MB and the time is much longer!!
AlexâŚvery thanks to You!!
