Xibo CMS Post-Installation Setup Guide
#1
Introduction
Once your 1.8 series Xibo CMS is installed, there’s some additional setup required to enable all functionality and to keep things running smoothly. This guide will take you through the steps needed.
Please note:
This guide relates to Xibo 1.8 series, for information relating to 1.7 series the old article is archived here.
If you have yet to install a Xibo CMS please follow the CMS Installation instructions appropriate for your environment.
If you’d rather not host your own CMS, then please do take a look at Xibo in the Cloud for hosting. Xibo in the Cloud customers benefit from pre-configuration of features and can, therefore, skip steps, as detailed below.
If you are running with Docker, please upload a test file (such as an image) to your CMS, and ensure that the same image then appears in the shared/cms/library directory on your local filesystem. If not, please do not proceed as your changes may not be saved.
Time and timezone
NTP
Xibo in the Cloud customers please skip this section and go directly to the Timezone section.
It’s very important that the time is correct on your CMS, and that the CMS timezone setting is set correctly for the timezone you’re working in.
You may want to consider setting up your Operating System to sync time automatically from the Internet so that the time is always correct.
ntp.org provide free access to time servers you can use to synchronise your CMS clock. Instructions for configuring access to their servers are provided here http://www.pool.ntp.org/en/use.html
Timezone
Now your clock is correct (and will remain so automatically), you need to let the CMS know what Timezone it should be using. The installer attempts to make an intelligent guess from the timezone that your OS has been set up to use, but it’s not always able to make the best choice.
Log in to your CMS and go to the Settings page under the Administration section of the Menu and click on the Regional tab.
Use the drop-down menu to select the nearest major city in your timezone, click Save at the bottom of the page.
CMS Maintenance and Email Alerts
The Xibo CMS is only ever running when a User is actively interacting with the system, or a Player is connecting to update its content. At all other times, Xibo isn’t running at all which means in order to carry out certain background routines (eg clearing out old records) or to alert you if one of your Players stops connecting as expected, we need a regular “wakeup” to run Xibo that will allow those things to happen. Xibo uses Tasks and XTR to run these routines.
Xibo in the Cloud and Docker installations, running XTR will happen automatically. For non-Docker installations please follow the configuration instructions for XTR-Routine Tasks
Email Alerts
Now the CMS is being regularly woken up, you can optionally configure Email Alerts to be sent when Players stop connecting properly, and when they come back online after a period of downtime.
Again from the Settings page located under the Administration section of the Menu, click on the Maintenance tab. Here you will see some settings referring to the sending of emails.
Xibo in the Cloud customers please note that some settings are pre-populated for you but are available for you to change, with others locked for editing.
  1. Enable Email Alerts? (MAINTENANCE_EMAIL_ALERTS) - is set to On
  2. Admin email address (mail_to) - enter the email address that should receive an email when a Display goes offline or comes back online.
  3. Sending email address (mail_from) - enter the email address alerts from the CMS should come from.
  4. Max Display Timeout (MAINTENANCE_ALERT_TOUT) - enter a time in minutes for a Player to be considered as gone “offline” from the last time you saw the Player connect to the CMS. This can be overridden on a per client basis should you need that. Do not set this value lower than your normal Player collection interval. If in doubt, set it higher. The default is 30 minutes.
  5. Send repeat Display Timeouts (MAINTENANCE_ALWAYS_ALERT)- if this is set to On, for each offline Display you’ll receive an email every time the maintenance.php routine is run. Most people will want this set to Off which means that you’ll be notified only once per downtime period.
  6. Save your settings by clicking the Save button at the bottom of the page.
In some cases, it’s also useful to alert Users/User Groups if a Player goes offline. To do this navigate to Users under the Administration section and use the row menu for the selected User record to Edit. Click on the Notifications tab and tick the box to Receive Display Notifications.
This can also be set against User Groups.
Next, you need to decide which Displays should receive alerts. Navigate to Displays on the Menu and for each Display you want to receive alerts for, use the row menu to Edit then click on the Maintenance tab.
Make sure Email Alerts is set to Yes. For any display you don’t want to receive email alerts for, set Email Alerts to No.
If you are not using Display Setting Profiles (see section below), ensure that you tick Use Global Timeout? tick box so that the value set earlier for the time a Display needs to be offline before being alerted is used. If you are using Display Settings Profiles, then if that box is unticked, the Collect Interval from the Display Profile will be used instead.
With Email Alerts configured, if you turn off one of your Displays, you should be notified by email. The email will be sent once the Global Timeout or Display Profile Collection Interval has elapsed since the Player last connected, on the subsequent run of the maintenance script.
Example: If the Global Timeout is 10 minutes and your maintenance script is set to run every 5 minutes, then you may not be notified for up to 15 minutes after the Player last connects.
When the Player comes back online, you will be notified instantly via email.
Please note: Multiple recovery emails are sent if the Player in use makes multiple simultaneous calls to the CMS when it starts up.
Log and Statistics Retention
Xibo in the Cloud customers should be aware that these settings are pre-configured and are not available to be modified, please skip this section.
The CMS generates log output when it’s running, and also receives log output from the Players connected to it for the purposes of debugging and checking the system’s state. It can also collect Proof of Play Statistics. All these records are held in the database and should be purged periodically to keep the size of the database manageable and to prevent system performance problems. The maintenance script performs that function.
Go to the Settings page under the Administration section of the Menu in the CMS, and click on the Maintenance tab.
  • Max Log Age (MAINTENANCE_LOG_MAXAGE) controls how many days logs should be retained in the CMS database before being automatically deleted. A setting of 5 would keep logs for 5 days and that’s reasonable for most debugging purposes.
  • Max Statistics Age (MAINTENANCE_STAT_MAXAGE) controls how many days proof of play statistics are retained in the CMS database before being automatically deleted. A setting of 30 would keep statistics for 30 days. If you need to keep them for audit purposes, they can be exported from the Statistics page in the CMS and archived for later use.
Regional Settings
The Xibo has built-in support for display of the user interface in alternative languages, and to show dates in alternative formats too (eg DD/MM/YYYY vs MM/DD/YYYY).
All translations are contributed by the community and we are very grateful for all Community efforts to keep the system translations updated and accurate. If you’re interested in improving the translations for a specific language, you can contribute directly via Launchpad Translations:
Edits made there will be automatically included in a future Xibo CMS release.
Language Detection
By default, the CMS will use the language preferences set in your web browser to auto-detect which language to display the CMS interface in. In some instances, for example, where only small parts of the CMS have been translated into a particular language, it may be desirable to disable language detection and enforce a specific language instead.
  • From the Settings page of the CMS, move to the Regional tab
  • Untick the Detect Language (DETECT_LANGUAGE) tick box
  • Select a suitable Default Language (see below)
  • Save your changes
Default Language
If you disable language detection, the CMS will need to know which language file to take its translations from.
  • From the Settings page of the CMS, move to the Regional tab.
  • The Default Language is en_GB which will give you English (British) translations. You can enter any valid code from the list of languages Xibo is currently translated in to. You can see a list here
  • Enter the language code, without the trailing .mo. So for example, to select Spanish, enter es
  • Save your changes
Regionalised Date Formats
By default Xibo CMS shows dates in Y-m-d H:i format (eg 2015-03-29 10:00:00)
The date format used throughout the CMS can be adjusted from the Settings screen by adjusting the Date Format setting on the Regional tab.
Display Profiles
Display Profiles offer a powerful way of centrally configuring your Player settings from the CMS. When the Players connect to the CMS, they will receive any default or assigned Profile you’ve created and reconfigure themselves with those settings automatically.
Profiles are located on the Display Settings page of the CMS. You can create default profiles for each Player type or individual profiles which can then be applied to one or more Players to override the default settings.
Full details on managing Display Profiles can be found in the User Manual on the Display Settings page.
Important Note On Collection Intervals
The Xibo 1.8 series comes with XMR push technology, which means that by default when you make changes to content assigned to displays in the CMS, the Players are notified to connect in and download that update straight away. It’s therefore strongly advisable to set relatively long collection intervals for your Players since those only really serve as a failsafe for any missed push messages.
You do not want 1.8 series CMS and Players with 1-minute collection intervals. 5 minutes is the absolute minimum for normal operation, and we strongly advise setting this value to 30 minutes or longer.
Proxy Settings
Xibo in the Cloud customers can skip this section.
The CMS will need to be able to contact external servers to pull in RSS feeds from outside your local network, or for integrations such as Twitter. If your network uses a proxy server then you’ll need to tell the Xibo CMS about it so it knows where to look.
From the Settings page under the Administration section of the Menu, click on the Network tab.
Fill in the proxy server details for your network. Your network administrator will be able to help you if you’re not sure what they are.
  • Proxy URL (PROXY_HOST) should be the http URL of your proxy server (eg http://proxy.mydomain.com or http://192.168.1.8)
  • Proxy Port (PROXY_PORT) should be the port number that your proxy server is listening on (eg 3128 or 8080)
  • Proxy Credentials (PROXY_AUTH) should be any username and password required to use the proxy server, in the format username:password eg jdoe:secretPassword. Leave this blank if your proxy does not require authenticated access.
  • Proxy Exceptions (PROXY_EXCEPTIONS) are any host or keyword that should be excluded from being sent to the proxy server. For example, if you have an intranet server then you could exclude it by entering intranet.domain.com. Multiple entries can be included by separating them with commas. Leave this blank if you don’t require any proxy exceptions.
Save your changes at the bottom of the page.
XMR
Xibo in the Cloud accounts come with XMR pre-configured so please skip this section
Docker installs of Xibo CMS come with XMR running automatically for you, and with most of the configuration in place, however, you do need to adjust the XMR public address of the CMS.
From the Settings page under the Administration section of the Menu, click on the Displays tab.
The XMR Public Address field defaults to tcp://cms.example.org:9505. We need to adjust this value to be suitable for your network.
If your CMS is available by a DNS name - for example, if your CMS web page is available at https://mydomain.com, then simply swap cms.example.org for mydomain.com. If your CMS is only available by an IP address, then enter the IP address instead.
If you run a local firewall on your CMS server, you will need to allow port 9505 inbound for XMR to work, as well as port 80/443 inbound for the web interface.
Third Party Integrations
Weather Forecast API Key
Xibo in the Cloud accounts come pre-configured with a Forecast API key so you can start using the Weather module straight away with no additional setup needed.
Since version 1.7, the Xibo CMS has the ability to show weather forecasts and current weather conditions thanks to an integration with Darksky.
Access to the Darksky API is protected and therefore users must register for an API key to enter into the Xibo CMS settings. Full details are available on the Weather page in the User Manual.
Twitter API Key
Since version 1.7, the Xibo CMS has the ability to search Twitter for interesting tweets and show them as part of a Layout.
Access to the Twitter API is protected and therefore,users must register for an API key to enter that into the Xibo CMS settings. The process differs slightly for Xibo in the Cloud customers as detailed below.
Xibo in the Cloud Customers
The process of connecting to the Twitter API is simplified for Xibo in the Cloud customers.
Go to the Modules under the Administration section of the Menu in the CMS, find the Twitter Search Module and use the row menu.
Click on Connect to Twitter which will bring up a form with a Login with Twitter button to allow you to authorise the CMS to connect via your Twitter account.
Click on the Login with Twitter button and follow the on-screen instructions to authorise the CMS.
Xibo Open Source Users
  • Go to https://dev.twitter.com/apps/new and log in, if necessary
  • Complete the required fields, accept the terms of service, and solve the CAPTCHA.
  • Submit the form
  • Make a note of the generated consumer key (API key) and consumer secret (API secret)
  • Move to the Modules page of the CMS and edit the Twitter module
  • Enter your API key and API secret.
  • Optionally adjust the Cache Period value to determine how long to cache a result set for each Twitter search. Please note: Setting low values can cause your access to the Twitter API to be disabled for generating too many requests.
  • Save your changes
Backups
Xibo in the Cloud customer accounts are backed up daily as part of your service plan
As with any system containing user data, it’s vital to maintain regular backups of your Xibo CMS.
Docker-based installs automatically take a daily database backup for you, as well as one as part of the upgrade routine.
As part of your backup plan, you should regularly take a backup of at least the following files/directories:
shared/backup/db/latest.sql.gz
shared/cms
config.env
*.yml
How you opt to make regular backups is left as an exercise for each administrator.
Here, however, are some links to utilities that may be of use:
duplicati - Windows/Linux duplicity GUI backup application
duply - Linux duplicity command line backup application
Remember for a backup strategy to be reliable and effective, it must be automatic. Don’t rely on remembering to take periodic backups manually.
Installing Xibo on web
Having problems with xibo player in windows!
How to Backup CMS
Can i install CMS in win Server 2012?
How install new translation?
Player fall back to desktop
Could Someone Please Help Me instal Xibo on my server :-0
Xibo Player stops working and show black screen
Bandwith chart translation
cURL is used to fetch data from the Internet or Local Network and is required
Xibo Email Alert: Display is Online again - comes multiple times
Layout not loading
Regarding on Remote Monitoring
Invalid Layout/No Media downloaded to windows client
Regions sometimes show up as white areas
The player get 503 error, Exception in Run: Could not find file *requiredFiles.xml*
Xibo client wont download any content from CMS
Restart layout at each interval collector (multiple client)
Disappearing regions
Install Xibo player Get error
No display character on window clinet
Upgrade to v 1.7.7 -> daily or sometimes hourly client freezes
Win Client does not Update Kampaign
Missing requiredFiles.xml win10
Text Marquee Effect Jitter
Problem with wrong library setting
Problem to display on Client from Server (Version. 1.7.6)
Notification when a error occurs at client site
Need help getting maintenance emails working
No Edit option on Modules
RSS ticker feeds don't show in region
Simple php page that only shows chosen status
Copy a layout to another xibo CMS Host
Configure my domain to access the Xibo
Local video loop problem
Cannot display layouts 1.7.5
Can't upload files bigger than 2MB
Weather IO ncorrectly configured module
Can not add videos
BUG International dates
Huge database backup due to log files
Powerpoint is not enabled on this display
Forecast 5 day | Wrong day names
Mailer not working
Twitter module displaying nothing
Validate Get_File statistique on Xibo client
Failing to Register my Client 1.7.4
[3rd Party] Getaweb Xibo Twitter module
Probleme with screenshots
XMR public adress
Email notifications help
XMR not working on CMS with port 9090
Xibo player 1.8.10 win10
DSCS9 never gets status "green"
Problem with update to 1.8
XMR collect message debugging
Download at client end
Xibo Docker upgrade problem
Setup smtp step by step
Xibo Player, Status Sleeping after a whole and half media reproductions
Inherited non-functional system
Alerting on screens down
Display is downloading 4 files too many times - Notification Means
Issues with mail
Email Notifications
Maintenance & Send Email Alerts
Xibo 1.7.7 on CentOS7 permission error
XMR configuration, step by step
Moving to Xibo 1.8.2 From Xibo 1.7.9
Show notification if player is accidentally shuts down while playing
Msql table log 135mb
Synology DSM6+ - Xibo Docker 1.8+ Installation
Best way to back up Xibo CMS installed on Docker
API Call through Postman
Xibo player Exception in run "could not locate requiredfiles.xml
XIBO SERVER.log too large and lot of xiboserver-bin files
Content failure
Strange dates in calendar
Fully qualified address of your CMS installation
Xibo Checklist for CMS Installation
Email alerts with "Use global timeout"
Maintenance Email Alerts not coming
How to set-up email alert for windows player
Display Update Window Confusion
Xibo maintenance - email
ScheduleManagerThread Agent threads are dead, not updating status .json
#2
#3
Failed to write file to disk
I am testing Xibo and have few issues with it while testing
Xibo player shows me just the background
Only splash screen plays
Xibo windows client only showing Xibo splash screen
XiboClient is not downloading requiredFiles.xml
Xibo server I cant upload videos, error "true"
Layout not playing for full duration
Request Entity Too Large
Preview only displaying background color?
