I’m trying to set up a digital sign for our school canteen with a region set up as follows:
A) Dataset: Today’s specials (1 page, 10 seconds dataset duration).
B) Dataset: Everyday menu items (3 pages of 3 data items, 30 seconds total duration)
I’m running into the issue that whenever xibo transitions between A and B, you only see the first item in B for about a second before it moves to the next page. Then, later in the sequence, it appears for longer and what appears to be the remainder of the time it was supposed to display for originally (around 9 seconds).
Is this the expected behaviour? Are the 2 datasets rendering in parallel but only visible at the relevant times, or is this a bug?
I received your layout and scheduled it to my local player, on the player everything seems to be correctly displayed for the durations specified, I’m not sure what cause this issue on your players yesterday - unless there were some adjustments made to the layout between then and now?
