after checking “Force https” i cant connect to the cms anymore, and unfortunately i cant figure it out.
Xibo runs with Docker on Ubuntu.
docker-compose ps gives the following results:
xibo_cms-db_1 docker-entrypoint.sh mysqld Up 3306/tcp
xibo_cms-web_1 /entrypoint.sh Up 0.0.0.0:80->80/tcp
xibo_cms-xmr_1 /entrypoint.sh Up 50001/tcp, 0.0.0.0:9505->9505/tcp
i tried setting the values CMS_SMTP_USE_TLS and CMS_SMTP_USE_STARTTLS in config.env to “NO”.
Clearly you can see i have limited knowledge, and similar topics here in the Support category didnt help much. My guess is I have to change something with the ports, but i dont no where
Any guidance is very welcome
thanks in advance
