Hi to all
I’m in Italy and I’ve a problem with weather module
When I insert latitude and longitude coordinates with DOT (for example 43.717851 10.961405) it doesn’t work because the system convert the dot with COMMA…
I enter the correct long/lat in the right format… I’ve tested also with a “string” and it works… but when I save, after page refresh, I find the . corrected in , and the module (obviously) doesn’t work
