I’ve recently installed Xibo CMS on a debian stretch server using the docker compose package.
Everything worked smoothly until I tried to connect with the windows client, then I got The server committed a protocol violation. Section=ResponseStatusLine with the android client I get unable to connect ot that cms address.
I also tried opening the CMS adress in Firefox where I get a bunch of gibberish, on Chrome I get ERR_INVALID_HTTP_RESPONSE, to me it looks like the cms is outputting malformed xml.
Something is fishy but the install seems fine otherwise (the self check says all good)… has anybody got an idea how to fix this?
Xibo is the only service running on the machine at the moment.
The web-gui is running on a custom port but CMS/XMR is on default 9505 and I am not using a proxy.
I did not check force https in the gui.
One thing I also noticed is that xibo does not produce any log entries, even when I set logging to debug level
Thank you for running the statement. Can you also run the following command and provide me with the response. Please note you will need to replace file.yml with the compose.yml file you are using:
