What is shown on the client status screen? Please post a screenshot. If you’d rather not in a public forum, please open a case with Spring Signage directly.
See the Required Files section. The client isn’t updating because the CMS Display Profile for that client is set so that the client only updates between certain times. You need to adjust that so that it can connect all the time and then restart the client.
There is a bug in 1.7.2 if you set the start and finish times to identical values. See:
Perfect, ya now that you say that it happened when I created a default layout after upgrading to v1.7.2.
Works perfectly now after setting the Start Time to 00:00 and End Time to 23:50
I have various Xibo clients all on 1.7.2 running Windows 8.1. After updating the software from 1.7.1 to 1.7.2 I noticed that my RSS feeds stopped updating. After trying steps to get them to update I ended up assigning the players the default layout from Xibo rebooting the players and then reassigning them my current layout with successful results.
Check the info screen. I expect you’ve created a Display Profile in the CMS which is preventing the Player from connecting to the CMS except for a very small window over midnight. If you fill either apply the patch mentioned above or set a wider window you will be OK
I have no Display Profile set. The only thing that is set with a schedule are my Campaigns which I have starting in 2015 00:00 and ending in 2020 00:00.
Oh right. It’s just the thread is about Android devices (and is in the Android room)!
Can you post a screenshot then showing the top right of the client information screen? It shouldn’t have anything sensitive on it but shows the Required Files status
It’s hard to say without having access to the CMS, but those are very likely 2 RSS feeds.
Check on the CMS that all your RSS feed URLs are valid, and that if any of them are accessed over SSL (ie start https://) that you’ve configured PHP to support that properly following the FAQ here:
