Hi all when i try to upload a picture we get file i get this error. file type not allowed
Thank
James
Is this docker or custom installation on a web server?
What’s the CMS library path set to in CMS Settings?
If you’d navigate to the Report Fault page and look at the environment checks, do you see any issues there?
If you’d navigate to the Modules page, find Image module, I assume the .jpg is there as a valid extension?
If it is custom instillation please, double check the php settings - How do I upload files bigger than 2MB / How can I increase the upload file size limit?
docker
i dont know the library path and the limit is set to 4gb and this was a 2mb jpeg, how do i upload the troubleshooting data
James
Peter https://community.xibo.org.uk/u/peter staff
August 15Is this docker or custom installation on a web server?
checks, do you see any issues there?If you’d navigate to the Modules page, find Image module, I assume the
.jpg is there as a valid extension?If it is custom instillation please, double check the php settings - How
limit?
https://community.xibo.org.uk/t/how-do-i-upload-files-bigger-than-2mb-how-can-i-increase-the-upload-file-size-limit/27Visit Topic
https://community.xibo.org.uk/t/cant-upload-images-to-xibo-cms/15438/2
or reply to this email to respond.To unsubscribe from these emails, click here
https://community.xibo.org.uk/email/unsubscribe/d7a0385b1fe7f94004dc068febb18a29afe3e342d8504b87bb1b6bbb0a6d3c15
just to let you know its an upgrade
If it is docker instillation then I’d expect it to work and be configured correctly.
Is it docker for Windows or Linux?
Would be best to go through Report Fault wizard in this case please.
You can upload the log files to dropbox/googleDrive or similar service of your choice and share them with me via private message.
