Hi Everyone.
Im having an issue when i try to delete one of my displays:
is the only one that show that error.
here is my troubleshoot log:
Hi Everyone.
Are you using manual or docker installation?
You can make a check on the display permission settings.
Digging in the log, i found this error:
25916,f64bc81,“2018-08-24 12:54:27”,WEB,/display/53,DELETE,"SQLSTATE[23000]: Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails (cms
.lktagmedia
, CONSTRAINT lktagmedia_ibfk_1
FOREIGN KEY (mediaId
) REFERENCES media
(mediaID
))#0 /var/www/cms/lib/Storage/PdoStorageService.php(239): PDOStatement->execute(Array)
I dont know if i should delete the display directly in mysql, or try to add the key and then try to delete it using the GUI.
That would be due to this bug - https://github.com/xibosignage/xibo/issues/1632
It will be fixed in 1.8.12.
We will also attempt to put a function in place to clear any existing issues with db on upgrade.
I should mention I also saw the bug when trying to assign a display settings profile to a display. Same error as pasted above.
Just to clarify, this issue is resolved in latest 1.8 xibo.
Is there any way i can mark this as solved?
