Is it possible to automatically take screenshots at a certain time? I found on the forum a note that someone did, but I did not find information on how to do it.
You can set ‘Screen shot interval’ in display profile assigned to your device -> Advanced tab
Obviously this might be bandwidth intensive, depending on what interval you set there.
Thanks, everything works fine
