Xibo running on IIS 7.5 on widows 2008 R2
I have followed instructions to upgrade from 1.7.0 to 1.7.9 fine.
Then I upgraded to 1.8.2 and had no errors during the upgrade.
I can logon fine, access the dasboard, displays, templates, settings, many others, but when trying to view layouts or media, I have an ajax error.
404 error on:
http://xibo.mydomain.com/layout?draw=1&columns[0][data]=layoutId&columns[0][name]=&columns[0][searchable]=true&columns[0][orderable]=true&columns[0][search][value]=&columns[0][search][regex]=false&columns[1][data]=layout&columns[1][name]=&columns[1][searchable]=true&columns[1][orderable]=true&columns[1][search][value]=&columns[1][search][regex]=false&columns[2][data]=&columns[2][name]=description&columns[2][searchable]=true&columns[2][orderable]=true&columns[2][search][value]=&columns[2][search][regex]=false&columns[3][data]=function&columns[3][name]=duration&columns[3][searchable]=true&columns[3][orderable]=true&columns[3][search][value]=&columns[3][search][regex]=false&columns[4][data]=function&columns[4][name]=&columns[4][searchable]=true&columns[4][orderable]=false&columns[4][search][value]=&columns[4][search][regex]=false&columns[5][data]=&columns[5][name]=layoutId&columns[5][searchable]=true&columns[5][orderable]=true&columns[5][search][value]=&columns[5][search][regex]=false&columns[6][data]=owner&columns[6][name]=&columns[6][searchable]=true&columns[6][orderable]=true&columns[6][search][value]=&columns[6][search][regex]=false&columns[7][data]=groupsWithPermissions&columns[7][name]=&columns[7][searchable]=true&columns[7][orderable]=true&columns[7][search][value]=&columns[7][search][regex]=false&columns[8][data]=function&columns[8][name]=status&columns[8][searchable]=true&columns[8][orderable]=true&columns[8][search][value]=&columns[8][search][regex]=false&columns[9][data]=function&columns[9][name]=&columns[9][searchable]=true&columns[9][orderable]=false&columns[9][search][value]=&columns[9][search][regex]=false&order[0][column]=1&order[0][dir]=asc&start=0&length=10&search[value]=&search[regex]=false&layout=&tags=&userId=&ownerUserGroupId=&retired=0&layoutStatusId=1&showDescriptionId=2&_=1507821198134
or library?draw… for medias
I have checked access rights, url rewriting,…
Can anyone help me?
Cedric
alex
October 12, 2017, 4:02pm
2
You definitely imported the rewrite rules? There’s a section of the manual dedicated to it:
https://xibo.org.uk/manual/en/install_environment.html#url_rewriting
Failing that, there’s an unofficial guide here which may have a step you’ve missed?
I want to share my experience for installing Xibo on Windows Server. I want to share if help anyone needs this kind of installation.
This guide will explain every step for IIS 8.5 on WINDOWS SERVER 2012 R2 Standart 64Bit. If any mistake please correct me.
XIBO Installation IIS 8.5 on WINDOWS SERVER 2012
Install Microsoft Web Platform Installer from Windows
Select and Install PHP 5.6 From Web Platform Installer
MYSQL:
Mysql 5.6 download from community and install (https://dev.mysql.com/down…
The import failed, it does not convert any rules.
I had to manually add it to the web.config files at that seems fine.
I found out the issue:
Default Web Site-> Request Filtering - Maximum Query String (Bytes) to 4096 (otherwise you will get datatables.ajax error)
That was it!
Thanks a lot!
Have a good week end!
Cedric
