Accessing Xibo 1.8.1 CMS from another computer on the LAN
I have installed Xibo 1.8.1 with Docker Compose on Ubuntu 16.04 VM server and would like to access CMS from another computer on the LAN. While looking for a solution for my problem, I stumbled upon the following in the forum which is exactly what I’m trying achieve.
Continuing the discussion from Access Xibo CMS from another computer on the LAN:
However, I’m assuming that this is valid for only Xibo 1.6/1.7 CMS, What should I be doing in Xibo 1.8, Docker based installation to achieve the same results.
Could someone please help? Thank you very much, kindly!
The Docker install will be listening on the IP address of your server, on port 80 by default. So you’ll need to find the IP address of your Ubuntu VM, and then Xibo will be at http://ipaddress
Thank you very much!
The only issue I had, was to figure out how setup network properties of my VirtualBox correctly and, like you said, the IP address of VM machine and it worked. Thanks again for such a great product and wonderful support…all for free!! :slight_smile:
