But running docker compose, I don’t see any PHP.ini file to update. Does docker compose put it somewhere weird?
Or has it changed since moving to docker? I normally only upload small files so it’s not been an issue but I have 2 files that are 800MB and 1.2GB that seem to have uploaded but it threw the gateway error which is a bit annoying so be nice to fix it properly so it doesn’t throw an error.
Not sure what the current server version is. I tried to update but seems to be the same version so not sure if it’s been a long day and just tired!
If you use docker-compose.yml correctly you should have included the file config.env
Within config.env you can uncomment the lines which you want to change. It is standard 2GB
## Xibo comes with a 2GB limit for individual file uploads
## If you require larger files, uncomment the following and adjust as
## required
# CMS_PHP_POST_MAX_SIZE=4G
# CMS_PHP_UPLOAD_MAX_FILESIZE=4G
# CMS_PHP_MAX_EXECUTION_TIME=600
