Hi There,
I have successfully installed zmq extension on my CentOS server.
but when I try to send a command to the display like requesting screenshot, it will just load, but not get any results.
Also, I have already added config.json file on vendor/bin/
Is there anything I missed? How can I test that it is totally working?
Thank in advance for you help…
Regards,
Junard
dan
2
Are you running the XMR application? After you’ve created the config file, you can start the application - ./bin/xmr.phar
There are example upstart scripts in the manual - or you can use your own preferred method to keep that application running all the time.
See http://xibo.org.uk/manual-tempel/en/install_xmr.html
Thank you for the quick reply… I will try to run this command.
Regards
Hi Dan,
I have try to run the command, but it says “Segmentation fault”… What does it mean?
Regards
dan
5
Sorry, i’ve no idea.
Can you provide full log output, etc?
Hi Dan,
where should I found the logs?
Regards
dan
7
I mean, what is the full output of the command after you start it? Just the segmentation fault?
