I manually installed Xibo 1.8.2 CMs. Only “ZeroMQ is used to send messages to XMR.” Gives a mistake.
I installed ZeroMQ and needed libraries seamlessly. Images of results reports have been added. Despite all this, the Xibo CMS still continues to give the same ZeroMQ error. I would be glad if you could help me with what to do. Thanks in advance.
Perhaps that an issue with bindings? Take a look here http://xibo.org.uk/manual/en/install_environment.html#zeroMQ
Any reason why you didn’t install it in docker environment?
As per http://xibo.org.uk/manual/en/install_docker_linux.html / Xibo 1.8.0 with Docker on Ubuntu 16.04 instructions?
With docker you wouldn’t need to make those manual steps, as it would be configured for you.
It may also be that you just need to enable the module (assuming it was installed correctly). I’m pretty sure just installing the module doesn’t enable it by default.
