Hi, I have a cms system installed on wampserver 3.1.4 on a my windows 10 64 bit computer.
I transmit information to 4 boxes android box in a local network.
I have problems with Zeromq since it does not send the commands to the boxes and it gives me the following error: ZeroMQ is required to send Player Actions. Please check your configuration.
XMR Private Address http://localhost:5555
XMR Public Address tcp://192.168.0.144:9595
“ZeroMQ ! ZeroMQ is used to send messages to XMR which allows push communications with player”
