I am on a custom installation (v1.8.6) on a server with plesk onyx on centos7
I have installed zeromq, the cms seems to throw the request to the display (which tells me that the problem does not come from zeromq) but XMR does not seem to work. I added the config.json file, the parameters in the cms look good.
But I can not run the command php xmr.phar, I have an error message:
PHP Fatal error: require(): Failed opening required 'vendor/autoload.php' (include_path='.:') in phar:///var/www/xxxxxxx-my-path-xxxxxx/vendor/xibosignage/xibo-xmr/bin/xmr.phar/index.php on line 15
and necessarily, display side: XMR Status : Disconnected
Can someone help meâŚ
PS: sorry for my english, iâm french, i try to translate as much as i can
Youâre running it from the wrong location - vendor/bin/xmr.phar is the correct place to run it from. Make sure your config.json file is in that same location and then try starting it from there.
Of course you will need some way to start that same comment during boot.
PHP Fatal error: require(): Failed opening required 'vendor/autoload.php' (include_path='.:') in phar:///var/www/xxxx-my-path-xxxxxxxx/vendor/bin/xmr.phar/index.php on line 15
Very strange indeed - I canât seem to recreate that problem here - the point of us distributing a PHAR file is that all of the vendor requirements are built into the phar.
I wonder if that message means that PHAR isnât supported by your PHP installation.
Can you create a file with <?php phpinfo(); ?> in it to see if PHAR is supported?
I came across this on a CentOS install today actually.
The issue is that Plesk, Cpanel etc bring their own PHP installations with them, so when youâre running âphpâ on the command line, thatâs not the same PHP as is being run when you call phpinfo(); from inside the webserver.
In addition, the command line version of PHP will have its own php.ini file in all likelihood.
So first, from the console on the server, see where the other installs of PHP are:
find / -type f -name php
Youâll likely find another PHP install somewhere either in /usr/local or somewhere else.
Run that php binary, with the -i option, and see if that lists zmq as enabled:
/usr/local/blah/php -i | grep zmq
If that outputs nothing, then run
/usr/local/blah/php -i | grep php.ini
to find out the location of the php.ini file itâs reading, and enable your zmq module there as well.
Then re-run the first check to see that zmq is now enabled.
Assuming it is, run XMR using that php rather than the system default php. As a side note, âlocalhostâ didnât work for me on CentOS. I had to configure the private port for XMR to use tcp://127.0.0.1:50001 explicitly.
he answers me : /usr/bin/php /opt/plesk/php/7.1/bin/php
so after : /usr/bin/php -i | grep zmq
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib64/php/modules/zmq.so' - /usr/lib64/php/modules/zmq.so: cannot open shared object file: No such file or directory in Unknown on line 0
/etc/php.d/zmq.ini
and
/opt/plesk/php/7.1/bin/php -i | grep zmq
/opt/plesk/php/7.1/etc/php.d/zmq.ini
zmq
libzmq version => 4.2.3
from there, I am a little lost and I do not know what I should do, if you could give me a little help âŚ
Itâs exactly as I wrote above. Plesk has brought its own version of PHP.
You need to use that to execute XMR.
So instead of
php xmr.phar
You instead need to run
/opt/plesk/php/7.1/bin/php xmr.phar
Itâs exactly reasons like this we suggest a Docker based install, as these Cpanel/Plesk like systems make it extremely hard to understand whatâs going on, and I suspect youâll find that when you next apply security updates to Plesk, Xibo will stop working and youâll need to make the same changes over again.
I will try to put myself in Docker but I do not master it yet âŚ
On the other hand I would be happy to manage to make run this installation on Plesk anyway:
But even trying to run the xmr.phar file with the good version of PHP (Pleskâs), I have the same error:
I do not know if I did the right thing, but I did: cd /var/www/xxxxxxx-my-path-xxxxxxx/vendor/bin /opt/plesk/php/7.1/bin/php xmr.phar
Failed opening required 'vendor/autoload.php' (include_path='.:/opt/plesk/php/7.1/share/pear') in phar:///var/www/xxxxxxx-my-path-xxxxxxx/vendor/bin/xmr.phar/index.php on line 15
[Service]
Type=simple
User={the systemuser of the subscription}
WorkingDirectory=/var/www/vhosts/{path to xibo}/ #make sure this is the root of xibo.
ExecStart=/opt/plesk/php/7.1/bin/php /var/www/vhosts/{path to xibo}/vendor/bin/xmr.phar
Restart=on-failure
One question, i have my service pointed to one installation of xibo, running well.
If I make a second Installation (diferent doman, same server VPS), will have to create a second service pointing to xmr.phar of the second installation or the service of the first is enough to handle all?
