I am trying to check or research if it is possible to show a line queue number on Xibo displays. Obviously it will work if you can show a HTML site as a layer or use a TV with HDMI input for an extra Device if you are using a third party solution.
But I am curious if someone has implemented an beautiful solution. I was trying to check with datasets and adding numbers, but we can’t use a keyboard input to trigger an interactive layout.
Does someone implemented this and also how did you achieved this.
I’ve done that before, but only as an integration of third-party services using an overlay layout with an iframe… This system was hosted on the client’s LAN.
Since my CMS are hosted in the cloud, I do not feel secure applying a native Xibo solution for this type of situation, as it would depend on having no client-side internet fluctuations.
This third-party service, as I mentioned, was installed on the client’s LAN, so even if there was a temporary loss of connection to my CMS, the line queue number system would continue to be displayed.
I don’t have much knowledge about how this third-party software works, as I mentioned, it was a system that the client themselves installed on the LAN. The integration was only possible because the queue number display was web-based.
That is actually a brilliant idea! this will give us the opportunity to use webhooks / https post as URL. Also we can implement our environment in a own network by our (medical) customer.
We are not going to use dataset for this, i will let our junior developer take a look into this if this can be build easily.
