Please do post your query into one of the available Categories available for this ‘Get Help’ section, so that you can be best supported!
Where to start… Recently started self hosting found a lovely VPS in Linux server SWAG is based on an NGINX module that auto validates for ssl hosts many popular containers but it does not however seen to host this one…
Have attempted the proxy, the subfolder ubder the proxy-confs and even the Default file under the site-confs. Have review Alex’s posts on NGINX but with the newer versions of Ubuntu am not getting anywhere
Attempted xibo.subdomain.conf
Version 2020/12/09
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name xibo.*;
include /config/nginx/ssl.conf;
client_max_body_size 0;
# enable for ldap auth, fill in ldap details in ldap.conf
#include /config/nginx/ldap.conf;
# enable for Authelia
#include /config/nginx/authelia-server.conf;
location / {
# enable the next two lines for http auth
auth_basic "Restricted";
auth_basic_user_file /config/nginx/.htpasswd;
# enable the next two lines for ldap auth
#auth_request /auth;
#error_page 401 =200 /ldaplogin;
#include /config/nginx/authelia-location.conf;
include /config/nginx/proxy.conf;
resolver 127.0.0.11 valid=30s;
set $upstream_app 192.168.101.31;
set $upstream_port 8080;
set $upstream_proto http;
proxy_pass $upstream_proto://$upstream_app:$upstream_port;
proxy_pass http://127.0.0.1:8080/;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
client_max_body_size 4G;
and xibo.subfolder.conf
location /xibo {
#auth_basic “Restricted”;
#auth_basic_user_file /config/nginx/.htpasswd;
# enable the next two lines for ldap auth, also customize and enable ldap.conf in the default conf
# enable for Authelia, also enable authelia-server.conf in the default site config
set $upstream_app cms-web;
and under the default file
location /xibo {
keep getting a 403. Am hoping for some insight
Thanks in advance
